The picture with green and red lines is the current setup. The green lines are outside walls and the red line is inside. If it's a load bearing wall would adding a wall where the yellow is and getting rid of the red most likely be okay? I haven't had time to get in the attic and look at the ceiling joists but the wall does run perpendicular to the floor joists. I will try to get some photos later.
