Hey all, new to the forum hopefully I landed in the right place..
I plan on removing a small wall separating my kitchen and dining room. The kitchen is on the first floor of a 2 story home, which is on a slab(no basement). The wall is about 3 feet wide. This wall runs parallel to the joists in the ceiling above it. The small wall has a double 2x4 top plate. This top plate intersects with the exterior top plate with a lap joint, like in the attached diagram. The small wall/ top plate are directly under a joist in the ceiling. Since this wall is so small and parallel to the joists I assumed it was not load bearing. After seeing how it intersects with the exterior wall and being directly under a joist I’m not sure. Any info or links are appreciated. Thank you.
