Hello, could someone please verify for me that this is not a load bearing wall:
Here are the details. Please let me know if you need more:
After seeing the beam in the basement I assumed this would be load bearing but it appears I can tear it out without consequence. The only thing concerning me now is that single joist resting on the wall. Can I remove it?
- There is a beam directly under the wall in the basement
- The joists in the kitchen (room where photo was taken) run perpendicular to and end at the wall
- the joists in the family room (other side of wall) run parallel to the wall
- the joists for the two rooms above run parallel to this wall
- there is no wall directly above this wall but about three feet into the family room
- one parallel joist above rests on this wall about .75"
- wall to the left is exterior if that matters
