I was priming over some stains in the basement this morning, getting ready for carpet, and I found this small wet spot. It is about the size of a man's fist. 3 years ago I had a little bit of water in the same spot before there was any drywall, but thought I had remedied the situation. The last time the water didn't come through the concrete, it dripped down from the top of the wall, between the top of the concrete foundation and the wood structure. I assume this is what is happening again. I believe the water is coming in the large gap between the concrete patio and the step going in the house. We've had quite a bit of rain the last few days.
My question for you guys is:
How do I patch the gap in front of the step? It also seems like a fairly large gap under the step.
Will the water dripping down the wall dry out on it's own? I don't have to remove any drywall, do I? There is about 1-2" gap between the concrete and the stud wall I built. There are 2 outlets about 4ft away, they are adjustable so I can take them out since there aren't wired yet and run a fan in the outlets.
Water spot.
Where the water is probably coming in.
Water spot.
