I installed a water feature at the rear corner of my yard and needed to get some power out there. I tapped into the "load" side of a GFI outlet on the shed and ran about 50' of 3/4 Liqui-Tite conduit to the location. I think this is a brand name but it's basically metal BX with a plastic coating that makes it water tight, and the connectors have O-ring seals. Same stuff they use for whips on a/c units, pool filters, etc.
At any rate, I have the conduit zip-tied to a chain link fence about 6" from ground level. My understanding is that you can use this stuff anywhere you can use conduit as long as it's visible? It terminates to an outlet box mounted to a 4x4 post about 6" from the fence. Is this installation up to code?
Anyway, almost a moot point because I'm tired of looking at this setup and thinking of renting a trencher to bury the line. Anyone know if this conduit is rated for direct burial or do I need to go to rigid PVC?
