So heres what going on, both my light about my sink and my overhead range light/fan stopped working. At first it went out, then it came aon a day later, then it went back out and stayed out been weeks now. So today i decided to take the cover off for the switch and take the light down to inspect for any loose wires or damage. So when i got them down didnt find anything except where the light was inside the metal box there is a black mark and on the white wires are dirty black. Im not overly familiar with exactly how my mobile home is wired but for some reason the light switch has a black and white wire and the light has 2 white wires wired to it. I took my voltmeter and at the switch it read 98v while it was switched off and 0v while it was switched on. At the light when you put the switch off it read 98v at either white one is combination with the black wires. and 0v at both the white wires coming to the light. Now keep in mind i have not altered any of the wiring at all before it was working and after it stopped working except today i changed the light switch. At the overhead range light/fan there is only 1 wire going into it and there is no power across the black and white.
