Hello all,
I moved into a house in the USA (WA) later last year. I lived in an apartment before (think it was a 90s build). In the apartment whenever we plugged and turned on the vacuum in the lights would go a little bit dimmer and remain dimmer until it was turned off. When I moved into our house (build mid 70s), great seattle area, the same thing happens. If I vacuum lights go dim temporarily. When the heating turn on (presumably heat pump and electric furnance), the lights will dip in brightness then return to full brightness. I kind of thought this is just American domestic lighting, but I'm willing to bet that more modern constructions don't suffer from this. So, what is causing this? What's likely to be causing this (I fugured it's a large current draw causing a voltage sag)? Is it my old breaker panel? Bad wiring? Shared netural/ground bar?
Thanks
Thanks
