I have a problem with lights dimming and then going back to normal. This happens every 3-5 minutes and they will dim for about 2 seconds and then return to normal. It only happens on one of the circuits in my house. The circuit in question is the main bathroom which also has an outside receptacle on that breaker as well as one receptacle in a room across the hall. The outside receptacle is on the same GFI as the one in the bathroom. I have unplugged from the wall everything that was in the other room across the hall (computer, printer, tv, ethernet booster from cable company) to rule out a load issue. I have checked the breaker itself and tested fine. I have also checked and tightened all wires on the neutral bar in the panel. At this time I am at a complete loss.
Okay. I work on computers by day and DJ at night so I am not by any means qualified to do electrical work. :no:
