True, if the lights and receps are on the gfci a 3 wire circuit will work. This might make sense depending on the layout.
Black = hot
Red = switched
White = neutral.
Power source
:2wire
GFCI
:2 wire
switch
:3 wire
:..........recep (blk/wht)........light(red/wht)..........recep........light....
Thanks guys. All of you have been great and I intended to do some trial and error to get the rest done, but you guys have been so cooperative, I will explain further what I would like to do.
I am running the power for both lights and recepticals from a GFCI breaker in a "logic box" that has a sub panel. The "logic box" allows you to push a button on the "menu" board to turn on the pump, underwater pool light, salt generator, pool heater, etc. separately. It also has a "remote control" option which I intend to use without having to go to the "logic box" each time I want to operate a device.
Naturally, I don't want to kill the power on the recepticals by pushing the column lights button to turn them off. Will I have a problem using this setup keeping the outlets "hot" all the time? Hope I'm not asking too much.
