I have a light that is controlled by a switch. It stopped working.
The two white wires are connected
The two grounds are connected and the two black wires are connected to the switch.
I have used a tester and touched the probes to the black and ground wires so the wire to the switch is hot
The wire to the light is hooked up white to white, black to black and ground to ground
The light will not work
I have used a tester on the wire coming from the switch and touched the probes to the black and ground wires and it is hot
The light works because I have attached it to another switch
