I'm installing double pocket doors and would like to install a 3 switch box next to the opening of the wall. If your familiar with pocket doors, these are walls that contain 2x4 split studs (to accommodate the doors). Each split stud is 3/4" deep and then I have the thickness of the drywall to add to it. I was going to use a double layer of sheetrock to get a decent depth to fit a box that won't impact the door inside the wall but I don't think even that will work. I was thinking of using a 1900 box (not sure how to use and/or attach) and then reduce the number of switches for the room down to 2. I could run the wiring down a 3/4" conduit to prevent interference there too.
I'm going nuts trying to figure this out and making it work...safely, too. Any and all help, ideas, and suggestions are more than welcome.
Thanks,
Joe
Thanks,
Joe
