New here with a quick question. I tried searching this question but only find people who have this problem after replacing switches/outlets which is not the case. Here goes...DH and I purchased a new home in early December, inspection passed good, no problems brought up with electrical. In the living room there is a light switch panel with 3 switches and the middle one controlled an outlet. I learned this one well because I plugged the Christmas tree into that outlet and used the switch to turn the lights on and off. Suddenly that switch no longer works for that outlet, it is just always on and the other two switches still control what they are supposed to. In the kitchen there is a similar setup, a panel with 3 switches and suddenly one of the switches doesn't control the outlet it is supposed to and is just always on. We have done zero electrical work. No replacing switches, outlets, or even covers. No other issues in the entire house. Whats up? Can I fix this? Mostly worried this is an early signal of an electrical problem that wasn't picked up in the home inspection.
TLDR: switches no longer control outlets. Zero electrical work or replacements of any kind done.
Thanks!
Thanks!
