We have one switch in our house that has been acting funny. It is in our walk in closet and sometimes it will turn the light on and sometimes it won't. Any thoughts here?
What kind of switch .. door jam switch or a typical toggle type light switch?We have one switch in our house that has been acting funny. It is in our walk in closet and sometimes it will turn the light on and sometimes it won't. Any thoughts here?
5. Bad switch.1. loose connection at switch
2. loose connection at fixture
3. loose light bulb
4. Chinese light bulb
joecaption said:Kill the breaker to that circut.
Remove the switch cover and check the switch with a Volt OHM meter set to OHMs.
Just flip the switch on and and off, wiggle the switch when it in the on position.
You do not have to disconnect the wires to try this.
See my post above. I did just replace the switch.jbfan said:Turn the power off and replace the switch for 69 cents.
If it doesn't work then, come back for more advice!
Missed that, sorry.See my post above. I did just replace the switch.
It's an overhead "dome" type light in our walk in closet.jbfan said:Missed that, sorry.
What kind of fixture?
Incandescent or fluorescent lamps?It's an overhead "dome" type light in our walk in closet.
Incandescentjbfan said:Incandescent or fluorescent lamps?
