Just wondering why a standard , plain jane light fixture doesn't have a terminal for the ground wire ? All the switches and outlets have it.
What about the metal screws used to mount it with ?
If they’re going into a metal box, they pick up ground because the metal box is grounded, because Code requires you tie metal boxes to the ground wires.What about the metal screws used to mount it with ?
If they’re going into a metal box, they pick up ground via the threads, because the metal box is grounded, because Code requires you tie metal boxes to the ground wires.What about the metal screws used to mount it with ?
