I have a fan/light in the master bedroom and wanted to connect it to zwave. I have used the dual relay module here.
http://enerwaveautomation.com/wp-con...8160044-01.pdf
Manual and zwave commands all work to turn the fan and light on/off separately. My issue is when turning the fan OFF, the light flickers for an instant and you can hear the relay studder.
Old Wiring:
Dual gang box in wall with 2 switches. Bottom leads on switches are hot. Top leads both come from same pair, 1 red 1 black (wires with twists). Neutral all together.
New Wiring:
Bottom leads of switches to hot. Top leads to AUX on the relay. Relay loads to load wires (red and black with the twist). Instead of adding a new wire for the relay hot, I simply connected it to the bottom of the light switch (hot) on the screw (may be my problem)...however I dont see how this would be different than running another wire to hot.
Old Wiring:
New Wiring:
What kind of light bulb is it? LED? Compact fluorescent? Incandescent or halogen?
That link did not work for me.
