Hi folks,
New here, looking for a bit of advice about the following behavior:
I have an upright lamp and a chest freezer plugged into the same wall socket. Not always, but sometimes when the freezer compressor turns off, and the lamp is OFF, the lamp will flash.
This makes no sense to me because the lamp's own dimmer is in the OFF position, so even if there was a current spike in the building's wiring, it would have to jump the switch to even get to the light bulb. The bulb is a small halogen.
The building is a 2011 construction quadraplex, so new.
The flashing is annoying, but I can deal with it. What's more important is to know if this is a symptom of a bigger problem. Should I just avoid plugging anything into the same outlet as a freezer?
Thanks!
Thanks!
