Hi - Hoping someone can assist with this. I'll try to provide as much information as possible. The light fixture i'm replacing works fine and has probably been in place for 30 years +. I recently replaced the switch and now am looking to replace the actual light fixture. I'll try to attach a couple of pictures ... Here is what I have at the switch and fixture. I just want confirmation that this is code. It doesn't make sense to me, but doesn't mean much.
At the Single Pole Switch I have two wires:
Red, White, Black
White, Black
Red Attached to switch
Black attached to the switch and spliced with other black
Whites both spliced together
At the fixture I found two wires:
Red, White, Black
White, Black
Red (Hot) attached to the White Wire from the fixture
Black wires are spliced together
White Wires Spliced together along with the black from the fixture
All wire is BX 14 AWG – no ground wires
Is this right ? This was probably the original fixture for a house built in 1965 … Any thoughts ? Thank you
Red, White, Black
White, Black
Red, White, Black
White, Black
