light fitting
1336 Views 8 Replies 7 Participants Last post by  bobelectric
hi im trying to find out how to fit a chandelier in a middle floor flat when i cant find the joist and the ceiling is plasterboard :(
1 - 9 of 9 Posts
Explain:
1) if you know where joists are but you don't want to use them (because not centered)
2) weight of lighting fixture
3) how wiring for power and a switch will be installed
Not exactly sure of your question but it sounds like you are trying to mount a heavy chandelier where there is no support. You need to use a box to mount the light and you'll need to run the wires to it as well as a switch location. Determine where you want to mount it. Get a heavy fan box like this one...
http://www.legrand.us/passandseymou...races/retrofit-braces/22200.aspx#.UOiYwHf-lug
You'll need to find a source of power. Either an existing circuit or run a new circuit from the panel.
... middle floor flat ...
I assume that your use of the term flat indicates you are in a place other than the US?
It would be advisable to include your location in your profile....
all the light socket etc is there but i want to hang a chandelier instead of a shade and i cant find the joist to take the weight, as im middle floor flat is there joists lol havent a clue and neither did my handyman
You have no clue which country you live in??
Electrical codes and practices are different depending on where you live ....
Time for a far more handyman.
Most often it's as simple as removing the old box and replace with one of these.
http://www.bing.com/images/search?q...EFB2DF15C63EC2885E2CDC4C188079F909903&first=1
It can be installed through the hole that's there now.
You can buy electronic stud finders quite cheap !
It's far cheaper then ripping out plasterboard.
Measuring instrument Tool Moisture meter Thermometer Wood
Flat means rental which means call rental company for approval.
1 - 9 of 9 Posts
