Hi Guys I hope you can help me
I've tried replacing my bedroom light from a standard celing rose to a 3-spotlight bar light.
On my first attempt I got the light working with no problems however I wasn't happy with the position I had installed it as it wasn't perfectly straight, so I adjusted the bracket and connected the light backup as soon as I tried to turn the light on the breaker tripped. I checked my wiring and decided that the wires were probably a bit tight now tht the bracket was moved slightly so I've made the hole bigger and reconnected everyting and again the breaker trips. I tried moving the light back to the original 'not straight' position but still no luck!
Whats worse is that even with no light installed - just the bracket. i cant get the breaker back on? The bracket is metal so could it be that it is effecting the cables somehow?
Any help you can give me would be much appreciated before I give up and call out an electrictian!
Robbie
Robbie
