I'm renovating a 100 year old house and need some advice for a subfloor issue. I replaced the original posts in the basement with teleposts and leveled the floor prior to starting work. This weekend I tore out the original flooring and planked subfloor and glued and screwed plywood with the intention of nailing bamboo flooring over top. Once I got the plywood down though I noticed a slight low spot near the middle of the floor. Measuring it with a 7' level it looks like the sag is about 3/16" over 4'. The entire low spot is roughly 15 sqft. After some investigation I realized that one of the load bearing beams in the basement has a slight sag between the two teleposts. The beam is 6 rough 2x8's, on edge, laminated together. The span between the teleposts is 74". It's the only spot in any of the beams that's sagging, so I suspect that perhaps there's a scarf joint inside the laminated beam that is giving out. I tried putting a bottle jack on a post and jacking the sag out, but the entire beam lifts up with the sag in place, making the two teleposts fall over. I jacked it up and let it sit overnight, hoping it might settle, but it didn't move a hair.
Unfortunately my drywalling & painting is complete, and to reduce the risks of redoing some mudding & painting I don't really want to jack up the entire floor to replace the beam, just to fix a 3/16" low spot. Also, it would appear that while the beam has a slight sag to it, it's certainly stable if I can put a jack under it and it doesn't even straighten out. Should I just lay some tar paper and mesh into the low spot and float some mortar across it? If I do that can I nail through it or will I have to use a floating floor?
Thanks.
Thanks.
