What's your taper jig look like? Is it manuf. commercially?Table saw and taper jig or circular saw and straight edge guide.
Same here.Table saw and taper jig or circular saw and straight edge guide.
The flooring section would be better place to pose the question.I don't know if I am in the right place. I am having trouble installing this st. james laminate flooring. The company gives you long, short, and medium length pieces. However, I can't establish a set pattern to laying out the flooring. can anybody help?
As stated above. The primary concern is to make sure end joints are stagerd.I don't know if I am in the right place. I am having trouble installing this st. james laminate flooring. The company gives you long, short, and medium length pieces. However, I can't establish a set pattern to laying out the flooring. can anybody help?
Thanks; now that I've seen it I know what is wrong with the one I built!:thumbsup:
Thanks; I think what I'll do is use two strips of wood with a hinge on the end and a wood screw on the other end that serves to separate the strips at the non-hinged end.Here's a couple of freebies I found on line
http://www.woodworkingtips.com/etips/etip020607wb.html
http://www.antiquesbuiltdaily.com/jigrefer.pdf
Better to start your own post in the flooring forum.I don't know if I am in the right place. I am having trouble installing this st. james laminate flooring. The company gives you long, short, and medium length pieces. However, I can't establish a set pattern to laying out the flooring. can anybody help?
Why would you need a shim 4 feet long?Does anyone make 4' long shims, 1/4" thk at one end and zero at the other end?
Do you cut your own with a fixture and table saw?
This is one of those how-I-should-have-done-it questions.
I s'pose with a bathroom floor 4' or 5' wide, depending on how flexible the subflooring would be and how forgiving the tile grout would be, I need to support the newly levelled subfloor along almost the whole length of each supporting joist?Why would you need a shim 4 feet long?
Ron
I think what Ron means is why do you need a long, one-piece shim?I s'pose with a bathroom floor 4' or 5' wide, depending on how flexible the subflooring would be and how forgiving the tile grout would be, I need to support the newly levelled subfloor along almost the whole length of each supporting joist?
Yet there are 14.5" between joists and that somehow works, so maybe just a few long shims along each 5' joist would be enough.
Yeah, that's another way to do it, and the strips would be uniform thickness.Personally, I'd just run strips perpendicular to your joists. about a foot apart, each one a little thicker (1/4"?) than the last one. Didn't someone already suggest this?
