The Whirlpool Side x Side fridge we got six yrs ago works great but for one prob: The right side door (fridge side) doesn't auto-close. The magnetic seal works fine but you have to close the door to get it there. Freezer door works great; it will self-close if it's anywhere NEAR shut.
The manual says to level the fridge to cure this. In fact, level is the ONLY thing the book lists as a problem when this condition occurs. Using my 2-foot bubble level, it was about a half-bubble off level when I started. This, measuring side-to-side, across front of the fridge. When I bring it to level, the door still acts the same way. There are no adjustments for leveling the rears.
Right now I'm out a couple hundred bux worth of food since the door was open about 1/2 inch all night, and the unit was warm inside this AM.
The doors are both hinged on the outside, opening from the center. Left door operates properly. Right side door does not .... and my common sense tells me that side needs to go UP in order to allow gravity to swing the door.
But lifting that right side up had no effect. FWIW, there is nothing heavy in the door, and it swings fine with no obstruction inside or out.
HELP!
HELP!
