I will be shimming joists with 2' shims (ripped from 2x4s) to level a subfloor and also repairing some water damaged subfloor at the same time and have a couple questions.
I know I need to add blocking under the subfloor where I will need to cut the T&G plywood, to support the subfloor at the seams. Where I am replacing subfloor and adding shims on top of the joists near the walls, I have had to cut the subfloor up to the bottom plate of the wall.
Do I need to add blocking under the subflooring that is under the walls? (For clarity, if yes, I would have the following from bottom to top: blocking | 3/4" subfloor | 2x4 subplate for wall | 2x4 wall framing.) If the answer is yes, how would I attach the blocking? Just toe nail from the open side? I am hoping the answer is no and that I can add blocking about 6" out from the wall and then toenail blocking from both sides to support only the edge of the subfloor as close to the wall as possible.
If I do not need to add blocking under the walls and I add the blocking about 6" from the wall as described above, is that sufficient support for the new subfloor along the walls? (There would be 6" lip of subfloor between the blocking and the wall that would not be supported. The seams I'm asking about are where the cut subfloor seam runs perpendicular to the joists.)
Thanks! Sure I'm leaving out necessary details, my first post here, so please let me know if there is additional information I need to provide.
