Hello to all,
My wellhouse needed a major exterior work over due to rotting wood. A Lg tree has also raised the S side of the foundation and it leans very much to the N.
I've included a few pics of a b4 & after, but the last 2 pics (of the back west side) at the bottom left somewhat shows the delta of the lean. You can see a 2x4 on its 1.5" side and the gap it creates. It still needs another 1/2-3/4" raise by the time it comes around to the front left (NE side)
In my first hand drawn pic, the bottom perimeter has treated 2x4 plate boards on the S W & N sides...the door or east side detaches and is removable so I can simply pull back from the west side and lower to ground to access well.
I'm looking for solutions to level out the foundation so when I put the well house back on, it's level. I cannot jack up the lower side or pour concrete to evenly level out the whole foundation. My thought was to measure highest point on the SE side, then run a 4ft level to the SW side and mark that height/point, then repeat from SW side to NW side to NE side and from NE side back to SE side; this completes the perimeter outside.
I was then going to frame up the outside w plywood even w outside existing foundation to the point heights measured w level. I'd then frame up the inside to match outside height and the width of 3.5" to match the treated 2x4 plate boards
Questions:
What is the best material to use to create this perimeter beam? The thickness would vary from paper thin starting out to prob 2".
Final question are suggestions on how to frame out the inside w existing tank, pipes, casing and other items close to the ground.
Thank you very much,
tstex
View attachment 591411 View attachment 591411 View attachment 591411
Questions:
tstex
