I am getting ready to lay ceramic tiles in my bathroom and was about to begin prepping the floor for install when I found the floor in not level. The floor is 3/4" OSB and is convexed in the center. Over a 4' span, the floor slops a minimum of a 1/4" as you move away from the center of the floor. Other than removing the OSB and starting over, what would be a good fix for leveling the floor? My plan was to use 1/4"-1/2" cement board underlay over the OSB. Another problem I have found with the bathroom floor is that the wonderful builder of the home decided the need for fasteners was nonexistent. The OSB is only glued to the joists. I had already planned to screw the OSB down, but I don't think that is a fix all...HELP
