I don't think the idea to change air is to avoid the plague, it's just that some common contaminants are accumulatory, like CO and CO2. Frequent headaches or sinus problems or upper respiratory problems could be very caused by sacred cow patties.I think the breathing concept is way overrated. Like the "need to change the air" concept. Its another sacred cow.
Its as if changing the air will prevent the Bubonic Plague. Dont worry about it very much.....
I think you are missing a great opportunity to live better if you don't ventilate an airtight house. I'm talking those that are under 2 [email protected], or maybe even 3. We have way too much plastic crap in our lives, like furniture fabric, rugs, toys, blah, blah. Besides, who wants to smell the dog farts all day? "Build tight, ventilate right." No, you won't see or feel the difference, but your lungs, etc, may. People who smoke don't feel their lungs filling w/ tar, either; same concept w/ ventilating, lesser degree.I think the breathing concept is way overrated. Like the "need to change the air" concept. Its another sacred cow.
The condensation means it was working and you just shut it off. That was a make up air damper used to bring in air that your appliances and bath vents exhausted. You did your home and family a disservice by blocking it off. A little duct insulation will stop the condensating.When we built our house about 7 years ago, the HVAC contractor installed an intake vent on the rim joist and connected a 6" round duct to the return air duct. There's a balancing damper at the intake so you can adjust how much fresh air comes in when the furnace runs.
In theory it works fine, however, I found that I would get condensation on the ductwork when temps would drop below 0F. I closed the damper and haven't noticed any ill effects since. No need to pay to heat outside air if my home has enough leakage already.
