1 - 20 of 22 Posts
The recent blizzard kicked my old arse with about 10 hours of heavy heavy shoveling at my place and GF's place. So I am thinking about getting a snowblower. I like the mid size 2-stage units (Ariens, Cub Cadet, MTD, Husq, etc.) that seem to be able to handle the range of dumps we get here. But my question: are these things even usable in a townhome situation? The only direction I could blow snow without getting it on neighbors' driveways and steps is back toward the road. I guess that would be OK before the road is plowed but maybe not after. Anyone here have a snowblower in a multi-family situation that can advise?
I can't comment on the logistics for your community, and my two stage blower does have a flap on the end of the chute that allows me to direct the snow right back down at the ground along side of where I am running it if I needed to, but in a community such as that you surely know somebody, or somebody who knows somebody, who has a blower. That's where I would start; asking someone who has been there and done that. You might even find someone nearby who would love getting a few extra bucks as long as they have theirs out.
· Usually Confused
In your climate you might want to consider going together with a neighbour or two in joint ownership. Quality blowers ain't cheap. The big problem with your small lot situation is keeping the snow on your own lot - just the same as with shoveling. As suggested you can direct the chute to blow just to the side or even ahead of you, but with big dumps like you just got, you won't get far before 'beside' or 'ahead' becomes overwhelming. Up here most municipalities have bylaws against depositing snow on town property, although I would hope in the situation you just had they wouldn't enforce it. Also, remember, if you buy a blower for the odd big storm, you still have to store it all year.
Discussion Starter · #6 ·
Thanks for the input guys. Yes, indeed, I figured directing the blown snow to go where it needs to go would be the main issue. As noted it can even be a challenge while shoveling to keep the stuff off the sidewalk (if it gets dug out by the association, which they didn't do this time... no place to put the snow) and off neighbors' driveways and the road. The road is community private property but it would still be bad form to throw snow into it after it is plowed. The only real option might be to throw snow into the road before it is plowed.
One tactic that might work is for all of us in one row to get a blower and then start on one end and throw the snow in one direction so that overspray would be re blown down until the end and thence into the common area grass. I can't see us getting that organized.
I don't know... I am healing up so will probably just keep my handy shovel for now. But what a PITA.
You just got a record snow. Don't run out and buy a big snow blower that you will need once every ten years. I have two snowblowers, one for snowmagedon snows and one for other snows. In your situation a one stage 208 cc quality snow blower would work for 95% of the snows. For the big snows, just go out about every six inches or so and use the one stage. They work great and are easy to use.
Discussion Starter · #8 ·
That's the Catch-22, the smaller snowfalls aren't all that hard to deal with using a shovel and really don't need a blower. But when the big dumps come, a little blower would be insufficient. Kind of irrelevant anyway since I have no place to blow snow.
We have had at least 4 events like this since I have lived up here. 1993 "Storm of the Century", January 1996 back to back storms, 2010 snowmageddon/snowpocalypse back to back storms, now this. I think these other events was as bad or worse than the 2016 blizzard and the ones coming 2 days apart really not much different than getting it all in one fall.
Bottom line, winter sux.
Discussion Starter · #11 ·
Here is a pic out my front security cam that shows the limited space for blowing or shoveling snow. This today after 5 days of melting. At least I can see over the canyon walls in my driveway now. :)
I'm not being negative, just honest.
You buy, fill the tank, use it once, park it and next year when you go to start it it has jello in the gas tank.
Most of us don't use our gas powered equipment enough to keep it running.
Put the $500 in the bank and hire someone to shovel the big bad-un's. I bet you don't run out of money and will be a lot less frustrated.
not with a snowblower, you can just blow it ontop of the pile...use some green marine gas stabilizer and no problems with gas staying in the tank till next season, also any gas equipment should be started every 6 months and run till heated up...
Discussion Starter · #18 ·
I've never used a blower but I imagine snow will drop out all along the path of the stream... and it might be hard to keep the aim locked on such a small target... and impossible to work in the direction toward the house at all so all work would be one way. It would take one of those monsters that throw 50 feet to reach that pile from the top of the driveway.
I think I am just going take my chances with the shovel for awhile longer.
nope, the smaller gas models can shoot snow a good 20 or 30 ft, you just aim the shut in that direction and you will be amazed how good your back feels, I have been using snowblowers since I was a kid going up and down the block clearing walks and driveways with a little toro snowblower, now I have much larger ones....you can get all the snow across the street much faster than shoveling and lifting or manually throwing it on a pile...you get a system worked out after the first time you go at it..
1 - 20 of 22 Posts
