Hello,
Trying to get some advice with the old Lennox Pulse G14 that came with the house I just purchased. Most local professionals don’t really like to work on them anymore so its kinda up to me at this point. I know this is an old furnace and people recommend moving on from them at this point but when it fires up its heats the house up super nice. I feel confident its safe. We have CO sensors in every room. I don't smell any gas around unit pretty sure there's no leaks in the heat exchanger. I wanna see if I can get as much life out of it as possible while i save for a newer model plus the A/C unit that is connected to it works just fine.
The thing works but not without some assistance as I'll get to in the next paragraph. I thought it was a spark plug or ignition control issue so i replaced both along with a new ignition cable. While I was at it I put in a new flapper diaphragm and gasket. New air filter. New smart thermostat in house. Drained the condensation trap. I shined a flashlight down the exhaust and intake tubes. Looks like theres no obstructions as far as I can look.
Nothing I did made it fire up consistently.. But as of recently I found a weird lil trick that makes it fire up first try and for the most part run on auto for the rest of the day. The trick is when the ignition sequence is in its phase where its sending a signal to the spark plug to ignite I turn the gas valve knob to OFF and it ignites and runs. Once I hear that sweet sound then I switch the knob back to ON and its in business doing its thing.
I have no idea what this means and why this gets it to start up first thing in the morning. It leads me to believe theres something with the gas pressure or the valve isn't working the way it should.. Is there anyone out there that knows what I need to do to get this thing to fire up without my assistance and this gas knob trick? I don't want this to become part of my normal morning routine haha.
