Hi we have a lennox G26 furnace the exhaust and intake pipes are run through the old oil stove chimney out the roof.
We have had several problems with this setup;
1-Water leakage during rainstorms.
2-intake icing up under ideal conditions several times every winter resulting in no heat until we clear the ice out.[not fun when it is minus 40]
We are thinking about relocating the pipes out the side of the house.
This past winter after getting sick and tired of climbing up on the roof I installed a capped t y fitting on the intake at the furnace line so when icing prevented the furnace from starting at 2:00 a.m. I was able to uncap the pipe to let the furnace draw combustion air from the house.
An additional benifit we realized of this modification is the high humidity levels we have experienced ever since we bought this house go away when running the furnace with the cap removed.
Are there any pros/cons or dangers to running the exhaust out the sidewall and drawing all the combustion air from in the house?
We went most of this winter drawing combustion air from the basement and have not noticed much difference in propane consumption.
The house is quite tight,we have to crack a window when we run the clothes dryer in the winter or ice builds up and freezes the doors shut.
This is the only gas appliance in the house.
