Made this its own thread.
If youve replaced the sequencer control and the elements are still lit up with no blower operation (thats what i assume from your post) .... then one or more 240 v. elements have either shorted out to ground (broke and touched the element frame) thereby completing a 120 v. circuit thru the element(s) which will keep them partially energized continuously until a fuse eventually blows or until its respective power wires melt and burn out.I got a Lennox furnace, electric and the heat comes on but goes off real quickly, I took off the furnace cover and it feels really hot and all, and when I look in at the squirrel cage fan, the elements are glowing bright red, I got scared and turned the breakers off at the bottom, all the trouble shooting points to the sequencers, so I bought another one for $59. and installed it, there are like 11 wires and I'm sure I got them all where they are supposed to be and all, I assembled everything and fired it up, and the same thing happened, so what else could it be? The relay? I don't want to call out a repair man and be raped, but if I do, then so be it,I live here in Salem Oregon, winter hasn't set in yet but it sure will! please help me Obi Wan Kenobi, you're my only hope!
