41 - 60 of 560 Posts
Discussion Starter · #41 ·
Most home owners build it all with screws, but best to ask inspectors if you are getting a permit and a permit is a suggestion.
I was not suggesting the perimeter, just that if that is a thought, the planning for it is before you build not after the frame is up.
Yes you would have the beam at 14 ft and you would use 16 ft joists, anything less and you would need another beam ..
We always add a second joist around the perimeter after everything is built but 2" bigger it makes things easier for adding stairs and a skirt below the deck
We take some off the bottom corner of the beam so it is less visible from the outside.
We like to lower the ledger against the house so we don't trap water, best it to just lower it 3/4"
And in line with the joist just a piece of 1x2.
So if you plan for this stuff like the extra 2x12 you might adjust measurements so the final wrap is 16 or you end up buying those 2 ft longer for little benefit.
Awesome thanks.
At the moment weren't planning on skirting because we wanted to store small things under the deck but if we do skirting in the future having that extra 2x12 would be good.
Is the 2x12 attached to the ledger or is it just screwed into the 2x10 that it's against?
I don't completely understand the ledger what is the grey block the rim joist? So pretty much just move my double ledger down 3/4" enough to fit a 1x2?
I have attached 2 images below and have some further questions.
For the image below I used the purple line to highlight where the extra 2x12's should be attached is this correct?
As well, the dark shading is where I'm going to add blocking and another joist beside the blocking is this enough for perimeter board? Some sites also say to add another joist beside that joist so essentially a double joist to help with the blocking. On J9 those small scribbles aren't blocking I just wanted to cross them out so you can ignore those but I do have blocking near the top. All blocking is 16" OC.
Product Rectangle Purple Textile Wood
For the image below I am worried about doing the layout correctly my plan is currently to remove all the sod from the area and then do the following as outlined:
1 & 2: Stake corner of house perpendicular with string line and ensure line is level. Then use 3,4,5 rule to make sure string is perpendicular and straight from the house.
3: Batter board 3' in to where the posts need to be placed taking into account cantilever use 3,4,5 to ensure straight and perpendicular again.
4. Use 3,4,5 to ensure straight still.
Finally line to wall and ensure we are all straight with 3,4,5.
Then I will mark the 3 post holes does this sound all correct?
Rectangle Handwriting Font Parallel Pattern
Thank you for the help!
retired framer
Awesome thanks.
The 2x12 would wrap the 2 ft return to the house at and would hide the fact that the double ledger is lower.
Top left corner
Rectangle Purple Font Parallel Pattern
What are the black marks between the joists on this picture?
Discussion Starter · #44 ·
Ah yes I forgot that it can wrap that 2' that makes sense.
The black marks are extra boarding for the perimeter board that needs to run parallel to the joists.
I saw in this article: How to Picture Frame a Deck: Proper Framing & Blocking
As shown it has an extra joist with blocking in it and then another support joist is this the way to do it or is there an easier way?
I understand that picture now I was just looking at it incorrectly thanks 😬
I have further questions now as I have forgot to take into account the stairs.
We were planning on having the whole front 16' as stairs with railing on the entire sides of the deck.
I'm not sure if this is ideal though..
retired framer
checking for square is nice if you assume the house is square . I would go with sight lines first and then check that for square.
Put a batter board up beside the house and nail a 2x4 to the ledger you have now.
Measure from the house 2 ft on both .
Pull a string to the third and let that dictate the side of the deck.
Rectangle Font Parallel Slope Diagram
And for digging holes for piers.
Rectangle Schematic Parallel Plan Font
retired framer
Full length stairs are nice but you have to cut a lot of stringers all identical and you would like them to land on concrete.
Wood Tradesman Composite material Lumber Landscape
Discussion Starter · #48 ·
Okay thanks your way looks a lot easier and more accurate.
I'll think of the stairs later haha.
I've looked around but I wasn't able to find a definitive answer I'm located in Calgary, AB do my footings need 6" of gravel at the bottom under the tubing or can I just put the tubing in my 4' holes without the gravel. Not too sure here.
I just wanted to run a perimeter board around but still not too sure how I need to set up my layout for this
Thanks!
retired framer
Thanks!
Do you mean for removing sod?
retired framer
I would start by deciding the very outside measurement of the deck.
Then you need measurements of the decking to figure the blocks you need for the perimeter.
Rectangle Parallel Diagram Font Drawing
Then you can subtract 1 1/2" for the 2x12 all around the outside and you have the measurement for the frame with 2x10 ledgers and rims. and you will have some joist that have a place to be.
Rectangle Parallel Font Drawing Screenshot
Then with out the 2x12 you layout and build the deck.
Rectangle Parallel Drawing Diagram Line art
Discussion Starter · #52 ·
For sod I would just throw boards on the ground
View attachment 697458 View attachment 697460
Sorry I'm unsure as to what these drawings are for could you explain?
In the other message I was referring to my cement footings. I've read in some places that I need to add grave to the bottom in the 4' holes before putting the cement pile whereas in other places people just put the cement pile straight into the 4' hole with no gravel.
Sorry if I'm super tedious I just don't have much experience and want to have this all planned out 100% so I don't fail miserably. I'm planning on using Trex composite decking 1x6.
I have attached another drawing I have some questions.
For joist spacing 16" OC joist 8 and joist 10 are 16" OC while joist 11 is just added is this correct to keep the spacing uniform from the first joist?
As well, considering the Trex decking the width is 5.5" so I have 1" overhang meaning I have 4.5" to work with then subtract the 2x12 and the 2x10 to have 1.5" of boarding required for the perimeter board. Considering this could I just place another joist there or is it better to do 1.5" blocking followed by a joist? I haven't added the blocking to this drawing yet.
Rectangle Font Parallel Wood Slope
retired framer
You want the bottom of the concrete to be sitting on solid undisturbed soil, when you are digging 4 ft deep it is hard to scrap out and loose that you have made or you may find water and make mud. So when in doubt about the bottom of the hole dirt, you put a little stone down there and pound it into the dirt as best you can with a post or 2x4 just to make it hard and a good base. Most people do a 2 board boarder because the framing for one is a little goofy.
So the spacer to the first joist with a single boarder is just 1 1/2"
Product Font Rectangle Parallel Brand
Usually you would do the lay out for the boarders first.
You know you need one at the 2ft bump out .
I would just start at the bump out and stop when you can't make another 16"
Rectangle Parallel Font Automotive exterior Line art
Discussion Starter · #54 · (Edited)
Ah so to be clear what I should do is a double picture frame border meaning I'd have 7" of spacing for blocking?
As well, am I correct that the width of composite decking is 5.5"?
For the image you attached the newest one don't I need to add blocking in the corner for the border and would that blocking need to go all the way down?
As well for the blocking spacing is it still 16 OC or do I need 12 OC for the blocking?
Also for flashing tape if I'm flashing 2x10's how wide of flashing tape should I use? 12" or do I want something even wider?
Rectangle Slope Parallel Font Circle
Thanks,
retired framer
Thanks,
How many boards are for the border one board or 2 boards.
Are you sure you want it in this corner, it changes a bunch of stuff?
Discussion Starter · #56 · (Edited)
Oops! For some reason I was thinking the perimeter board would go around the entire deck but now I understand it's just the outside perimeter.
I have attached a drawing for the 2 board perimeter does this look accurate? The boards are 7" in width with 16" oc spacing.
Font Rectangle Parallel Pattern Paper
I'm also trying to draw the perimeter board but at the top left corner I'm not sure how that will look with the 2nd board. The second board would run onto the house or am I visualizing this wrong?
Product Rectangle Textile Wood Font
Dangit I also just realized that my right side ends in the middle of my big window any suggestions as to what I should do or is it fine to end in between the window.
Also not sure if I ever mentioned but my deck will be about 30" high if that changes anything.
The grey in this picture is a joist hanger
Since I'm beginning the ledger board replacement you mentioned here to move the ledger down 3/4" so move it down 3/4" on my house is what this means?
I will be using vinyl z flashing above the ledger board along with flashing tape under the ledger and on top of the vinyl flashing but do I also need vinyl flashing at the bottom of the ledger?
Another question how exactly do I go about flashing a double ledger? I see information for a single ledger but nothing for a double ledger.
Thanks,
retired framer
Thanks,
Yes I think 7" works .
Now when you drew out the 16" on center you ended up with an extra close to the outside edges.
Remember that 16" is max and anything less is better.
If you have a space like 40' you would have a joist at 16 and 32, but you could back up and change that layout to 13"
and have joists at 13, 26, and 40 for the same money and a better frame. When you are not doing plywood you have more freedom with the lay out.
But yes the picture looks like you have a handle on it.
And blocks for the boarder can be at 16" on center.
retired framer
You asked about tape some time ago.
I am not sure what you have available, I retired before it got into use here.
I think 2" wide for the single joists, 3" or 3 1/2 for the double around the edges, you don;t want that showing to the outside. and for the ledger about 6 or 7 inches for the ledger and up the wall behind the house wrap.
Discussion Starter · #59 · (Edited)
Sorry if I'm back tracking but in reference to this picture I see documentation that has the decking fitted into that 1x2 space with the joist underneath the decking.
Is the above the same as below but instead there is a 1x2 in the gap and the joist lifted up higher against the 1x2?
Wood Rectangle Wood stain Hardwood Flooring
Ah ok so using this methodology and working off the picture below to the right of that joist there is 42" if I go up to the joist beside the blocking. So ideally would I use 14" spacing? Since I can have joist at 0", 14", 28", and 42".
For the left side it's 134" so it would be best to do 12" oc spacing? 0", 12", 24", 36", 48", 60", 72", 84", 96", 108", 120", 134"?
Thanks again I will try to research more into the flashing
Rectangle Parallel Font Automotive exterior Drawing
Discussion Starter · #60 ·
I'm also still having issues understanding how to flash a double ledger board. I have only found methods for a single ledger board if anyone can point me in the right direction thanks! Also I noticed that the double ledger extends past the house and I don't have any examples on how to flash for when it extends off the house.
