I'm considering installing some under cabinet lighting in our kitchen. I'd prefer not to have an exposed cord running from the outlet to the bottom of the cabinet, but will do that if what I'm thinking won't work.
My thought is that I'd like to install an outlet up at the top of the cabinet, possibly inside it—or even in the wall immediately above, where it can't be seen from the floor—and fish some 12/2 up from the outlet that's between counter and cabinet. Then I could plug the LED driver into the upper outlet and run the low-voltage wires either down inside the cabinet or behind its back panel, to the space where the lights would be, just under the front frame. Fortunately, I do have an outlet on an interior wall (no insulation in the cavity to deal with).
Anyone see any gotchas with this idea?
