1 - 6 of 6 Posts
Semi-Pro Electro-Geek
LEDs are often not properly dimmable, or don't dim the same way that incandescent lamps do. They can still produce light at very low currents, which incandescents don't. Some dimmers are incapable of completely shutting off current flow unless the switch is in the off position. Even then, ay kind of illuminated switch will draw a tiny amount of current. This doesn't cause a problem with incandescent lamps, since they stay dark at low currents. LEDs may light up a tiny bit though. About the only solution (other than using a different switch or different LEDs) is to plug a traditional incandescent night light, Glade air freshener, or other small load into the same receptacle as the rope lights. This will pass the tiny amount of current the dimmer supplies when turned down all the way, keeping the LEDs from lighting.
BTW, it's not code compliant to have a dimmer control a receptacle, unless you use a special receptacle with an odd shape that nothing normal can plug into. I violate this rule in my bedroom so I'm not going to say you shouldn't. But it's not code compliant.
Licensed Electrical Cont.
Is the problem one a 3-way? Maybe it is not actually off.
Me thinks the original post was removed. :huh:
Electrical Contractor
There were 3 threads about this when I answered one of them, and notified the duplicate status of the other 2. Seems that they all have been banished?
Thanks, mpoulton. As far as I know it's not a major problem, but I may try a night light as you suggest. Electrical inspection should be this week. We shall see.
1 - 6 of 6 Posts
