9.5 watts?How many LED 6 inch lights can you put on a new 15 amp breaker when it is rated at 9.5 per light?
At 9.5 watts per light you could add 189 lights to a 15 amp circuit (1800 watts) per NEC code. Sure you want to that?How many LED 6 inch lights can you put on a new 15 amp breaker when it is rated at 9.5 per light?
He specified LED can lights. Ive only seen them come as a total unit not as an empty housing that you can install lamps into.I believe it depends on the maximum wattage rating of the cans you're using -- not the bulb you ultimately choose.
I assumed the op was referring to something like the cree cr-6.He specified LED can lights. Ive only seen them come as a total unit not as an empty housing that you can install lamps into.
If he means regular recessed housings that will accept incandescent lamps, them he is limited by the rating of the fixture.
If you want to follow "best practice" it should be based onI believe it depends on the maximum wattage rating of the cans you're using -- not the bulb you ultimately choose.
