I'm not an electrician, so of course i cannot figure out if these bulbs are LED or conventional bulbs. There are no markings or engraving on them, thanks
Edison refers to the E26 base. Edison base lamps can de incdescent, halogen, CFL or LED.Edison bulbs are LEDs? I didn't know that.
I like installing and using the Edison base LEDs. I'm guessing with the millions of fixtures out there that there will be replacement bulbs for a very long time.
Bud
I have to disagree. Use of a LED Edison based lamp of any kind in a fixture designed for incandescent lamps is inherently inefficient. LED fixtures are designed to take advantage of the directional nature of the LED and focus the light where it is needed. You are wasting lumens sending them in directions that are not useful with an Edison based lamp . Additionally many Edison based LEDs do not last in fixture with enclosed globes (heat buildup).I like installing and using the Edison base LEDs. I'm guessing with the millions of fixtures out there that there will be replacement bulbs for a very long time.
I have had to buy for specific applications the fixtures with built in LED elements and if they fail the fixture would probably need to be replaced. Long warranties mean nothing 20 years from now.
Bud
Definitely leds.I'm not an electrician, so of course i cannot figure out if these bulbs are LED or conventional bulbs. There are no markings or engraving on them, thanks
No doubt. The burden of those fixtures, however, is they must be built to support incandescents, on the off chance some "cold dead hands" type insists on sticking a 100W incandescent in there. This limits the elegance of their design.I like installing and using the Edison base LEDs. I'm guessing with the millions of fixtures out there that there will be replacement bulbs for a very long time.
Well, the theory is that the LEDs are supposed to outlive any of us. And the LED emitters certainly will. The problem is the electronic driver that converts mains power to constant-current for the LED, made with third-rate capacitors and RoHS solder.I have had to buy for specific applications the fixtures with built in LED elements and if they fail the fixture would probably need to be replaced. Long warranties mean nothing 20 years from now.
It's sad that we're reduced to "find that"s and "seem to"s by lazy sellers. The seller should be plainly stating all that info - dimmability, CRI, color temperature - right on the package and on the sales webpage.I like those old-fashioned style LEDs, I find that they are the most 'dimmable' LEDs that I have come across, and they all seem to be a nice warm light, in fact some of the glass bulbs are amber tinted. Downside, the long strings of little LEDs inside are quite fragile and you can break them if you drop the bulb.
Yes.Well, the theory is that the LEDs are supposed to outlive any of us. And the LED emitters certainly will. The problem is the electronic driver that converts mains power to constant-current for the LED, made with third-rate capacitors and RoHS solder.
I have to disagree. Use of a LED Edison based lamp of any kind in a fixture designed for incandescent lamps is inherently inefficient. LED fixtures are designed to take advantage of the directional nature of the LED and focus the light where it is needed. You are wasting lumens....
