1 - 6 of 6 Posts
Hello All,
I just moved into a new home. Our garage has fluorescent light fixtures on the ceiling. One of the fixtures wasn't working. I noticed a broken tombstone & changed it out - it still didn't work. I took the fixture down & apart & discovered some grisly details - the ballast - I guess that's what it's called - was oozing black stuff. A link to some photos is below.
A quick Google search suggests this may be dangerous PCB's - I'm not sure. I don't have a will - should I make one up asap?
https://www.dropbox.com/sh/w820jnjh1dvquzo/AAAUkEwqwV4G22_DdlaTD6gSa?oref=e&n=519340264
· A "Handy Husband"
Ballasts made before 1978 did indeed contain PCBs. It was banned after that date and the label on the ballast must state that it contains PCBs. No label probably means that it contains no PCBs.
Still I would not worry about it.
· Super Moderator
common occurrence. Just clean it with varsol or paint thinner. Replace the ballast. I would go with a new T8 ballast. Rewire the tombstones to the drawing on the new ballast. It will not be the same as what is there now.
Or you could involve your state EPA and watch you bank account go to zero and possibly worse, only to find out the ballast did not contain PCB's. Do as was noted above.
1 - 6 of 6 Posts
