I have come across a seemingly easy fix (broken wax ring seal), BUT the slow leak has gotten out about 1' radius around the toilet flange. Now, I'm assuming I have 2 options, neither of which is optimal:
1. Cut holes in drywall downstairs under the toilet to see if I can ventilate the wood area around the flange.
2. Cut out floor tiles especially where it moisture meter reads above 70%.
What would you choose? I currently have 4-5 extra matching floor tiles on hand that the previous owner left. I'm concerned that by trying to remove 1-3 tiles I will butcher other tiles and end up replacing the entire bathroom floor.
Best tool? Angle grinder through the grout?
