I have a Rheem 3 ton R410A split system. The valve stem on the suction side has a small leak. Is there a way to repair the stem with out replacing the valve or loosing the charge? It is leaking from around the stem on the service valve where you use a allen key to open and close the service valve
Thanks for the reply, but what I am talking about is not the schrader valve. It is leaking from around the stem on the service valve where you use a allen key to open and close the service valve. I hope I explained myself better?
