Damaged threads on the pipe, or in the fitting, look in with a flashlight. Worst case, cracked fitting. Damaged threads can usually be gapped with tape and or pipe dope/putty. Cracked fitting will have to be replaced. Easier to access from behind, even if you have to tear out drywall, easier to fix than tile.
