1 - 20 of 24 Posts
I'm stuck on the first step - getting the handles off. I popped the plastic caps, took the screws out, turned the handles to the open position - they didn't come off. i tried the handle puller tool, but the l brackets slip over the back of the handle. I tried using a c clamp to keep the brackets in place, but that idea didn't work out either. I had one of the three handles off a few months ago, but now it's stuck on as well as the others. Here's what the handle looks like. You can see why the puller doesn't work. It doesn't have enough to grab on to -
· Roofmaster
Is this fixture and stall really as cruddy as it looks in the pictures?
Stop up the drain.
Get a helper. Tape a block of 2 x 4 on each side of the knob. Using the hook end of two wonder-bars, put even pressure on two sides of the cup (Back end) of the handle while your helper lightly taps the handle with a BP hammer. Hopefully it will walk off. When you reassemble, put waterproof grease on the spline after cleaning it and the inside of the handle thoroughly with a SS wire brush. Maybe boil the handle in vinegar water. Good Luck to you!
· Retired Moderator
work some penetrating oil (PB Blaster) until the splines by spraying into the screw hole and working some in from behind with the straw----
· Roofmaster
Hi Mike, PB Blaster reduces rust, does it work on soap scum and white rust too?
To Poster. You could get a piece of 1 x 4 oak and cut a slot in its center the size of the barrel behind the handle. Put a bearing board to the left, and pull on the right.
DO what mike said first if PB works on whats in there. I did not know it did, but I use it on rust religiously!
I've got Knock 'er' Loose and WD-40, will either of those do? jagans - I have oak boards but that will be a precise cut - a 1/16 or maybe a 1/32 off and it will slip over the handle. joecaption - That's a nice looking tool. Mine doesn't have the built-in clamp part on the "hooks." If it did we wouldn't be having this conversation :(
Knocker loose or the WD-40 should help. Take the screw out and soak the hole really good, it will seep in to the splines-- let it sit over night. I've got some just like that. You might even have to add some heat, and soak it again. When you do get them off, put a generous dose of plumbers grease on the splines and in the screw hole before re-installing them and you won't have any trouble getting them off next time.
Can chrome be heated?
I heated some of mine, i had to. If it ruins the finish, i believe a new set at Lowe's is about 12 bucks. Put a glove on and work the handle with an up and down twist on the spline while it's hot to break it loose. You may need a new set anyway if the spline parts are shot. Be careful with the heat if that is fiberglass behind it, all mine are tile. Also remember that WD and Knocker loose are somewhat flammable too.
(i operate a motel and have 26 sets of what looks like the exact same handle, so i've had to try just about everything, but the plumbers grease on the spline before you put them back will prevent this from happening again).
Discussion Starter · #13 ·
Got the center handle off! You mean to tell me a little 3/8" long spline has been giving me all this trouble?!
I looked down the barrel and saw what looks like a little nut over a bigger nut. Does it matter which one I turn?
Joecaption is correct (as usual).
if yours are like mine, this is similar to what you are looking at
http://www.lowes.com/ProductDisplay...gId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
It may not be exactly this one, but it is probably similar. When you get it out, take it with you and match it up at a plumbing place or box store. There is one for cold and one for hot (hot turns ON to the left, cold to the right).
Discussion Starter · #17 ·
I've got the special sockets for the valve stem. I haven't removed any stems yet. Why does the entire stem need to be replaced? I thought I could put on new washers and valve packing and be done with it.
You may not have to replace the entire stem. You can rebuild them as long as they aren't worn or damaged. I keep rebuild parts on hand for mine because i have so many, but i would also recommend changing the stem seats while they are out (use plumber's grease on them also). If they are original, they likely need it. It takes about a minute to do each one, and it only costs a couple of bucks. I learned the hard way it's better to do it now than have to pull'em again later.
:thumbsup:
1 - 20 of 24 Posts
