hello- my question comes from an addition that was built 3 years ago. we recently had cable tv installed and the tv shows wavy lines and you can hear a hum on the set. Direct tv (same location) doesn't do this nor does regular tv. this is using AV cables, when we switched to an HDMI cable it got better with less interference but it didn't go away.
the cable installer said I needed to ground the new cable he pulled from the pole. I installed a ground rod and he grounded the cable to it. the problem was still there but it did improve.
the installer was on the phone for awhile and came back and said I had a leaky neutral in the house. he said the cable is grounded/bonded with our electric company from the pole and when it is plugged in the box is searching for the electric co's ground because the house isn't sufficient. he suggested I use a generator to supply power to the cable box to see if it solves the issue and then if it does I should trouble shoot the circuit the outlet is on.......
I have never had this problem before with my electronics but I have never had cable here either........
I have not tried a generator or other outlet to test as this is a back up service and we rely on satalite. I do wish to fix if trhere is an electrical issue though.
how do you trouble shoot a circuit for a leaky ground? I used an outlet tester and everything checked out.-----
