The PVC pipe on my HVAC is leaking. I can see the water leaking through the purple sealant. Is there a simple solution? Can I simply go to Home Depot and by sealant and apply? I'm attaching pictures. Thank you!
Call the HVAC man. I assume you have a company that services your unit. Give them a call and they should be able to fix you up.Thanks. If I have to call someone though, would it be a plumber or HVAC repair? I have virtually no tools/experience. I'll try the primer/glue suggestion first though.
