Sorry for the length of this...
I've had a leakage in the basement for at least several days that I thought was some new just, you know, basement leak. :wink: However, several things started leading me to believe it might be the water heater and so early today I called a guy in to come look at it.
And it's leaking. Once he got some covers off and showed me where, I could see it slowly dripping.
I am in a position I despise, that I have to get this thing replaced fairly quickly, and do not have the usual amount of time to do research, shop around, etc. I might have enough for a couple of quick showers and I don't mind leaving the dishes a couple of days. But I'm going to have to get this replaced fairly quickly.
So questions/information are:
1) He says because the leak is coming from the inside it can't be repaired and needs replaced. Anyone not believe that?
2) I have to get a short part of a gas line replaced that he claims is not up to code. Given how old it is, I do believe that.
3) His company only deals in Smith and Rheem and he personally recommended the Rheem. I guess this is one of my more important questions, whether that brand is indeed any good or if I should be trying to call elsewhere. (It's a 22V36F1, though it's also supposedly a 40 gallon.)
4) It's gas. I guess that's important to know. :laughing: I did check those tankless ones real quick, but I think I don't have time to go off a completely new direction and don't know if it's worth it. While I live alone and don't need 40 gallons of water heated all the time, I do keep the temperature just high enough to not run out on an average shower and no higher.
5) He quoted me $1400, installed. Does this seem ludicrous? I know it's very high compared to the prices I've seen on the water heaters alone. But I absolutely cannot install it myself, and this includes replacing the small part of the gas line that's out of code, and it won't fit as is, so both the in and out lines (copper) and the vent (some thinnish silver metal) have to be changed a bit, tho I don't think that's a big deal. Couple of other minor things he has to do.
One of those times I might have to just bite the bullet and go for it, as long as that brand doesn't suck, cause I just don't have time to do much. Just in case I try to call for a couple of other quotes, what other brands are good? My old one is a Kenmore - it's over 20 years old.
