The plastic cap on the fill valve is leaking water all around it and I can't turn it to tighten it either clockwise or counterclockwise or take it off also I remove the nut at the bottom of the fill valve but the fill valve wont budge when I tried to remove it in the tank as well I follow what needed to be done but it did not free up the fill valve to remove I also took off the white plastic collar which was on top of the plastic cap what can I do?
please help frustrated I could send a photo of the inside if that would help
this is a tall eljer 141 2120
thanks
andy
