Hey all,
I tried to replace the drain valve in my hot water heater last night and I think I messed things up worse.
I'm attaching a picture of what my drain valve looked like (this is my first post so hopefully I did this correctly ...). Basically it was a cheap plastic piece that fit over a metal nipple.
What I TRIED to do was remove the whole metal nipple. That did not budge and I ended up popping the cheap plastic piece off, leaving me with a plain metal nipple, male threaded. But the replacement drain valve I bought was also male threaded.
Sooo, I ended up buying a fitting, using a bunch of teflon tape and attaching the fitting to the nipple, then the new drain valve to the other end of the fitting.
Unfortunately, I think I damaged the threads on the metal nipple when I tried to remove it and it's still leaking.
So, my question is, does that metal nipple come out? I was afraid I was going to break it. I guess my options are to try to get that nipple out and replaced or try to fix the threads on it.
Any suggestions?
Any suggestions?
