I found a crack in the caulk that seals this siding trim to the front brick wall. I pried open the crack a bit and can see the wall OSB behind it. It seems odd to me that the only protection against water/wind is a bead of caulk. Shouldn't there be some flashing behind this to channel water? I am trying to find proper installation instructions for this piece (and the name of the piece) along with what (if any) proper flashing should be installed at this brick to vinyl siding transition. Any suggestions? Thanks!
