Can't comment on how much carbon monoxide may have also leaked a bit.
But, right behind silver clamp, notice a bit of black schmutz. That's because there used to be a pliable type black putty where the pvc meets the backside of the clamp. You've solved the condensate drip. Now for safety, make a snake like bead of putty to place around the pipe and press into position. If you are a silicone insister, 100% silicone globbed all the way around will also work.
It appears this may not be the original induced draft fan. Whoever swapped in a new one didn't follow instructions.
Putty or silicone on both sides of clamp wouldn't hurt.
