I have a leak and need help . My son has tried several times to seal what he thought was the problem but it still leaks . I have a cement tile roof , the leak is in the back of the house , so its all on 1 slant.
The roof is in great condition but up around the top point where you see the vent , there was some craking in the cement , so my son bought some kind of cement patch / sealer and put it all along under that vent area, it still leaked , he did it 2 times more and the last time he bought a strip of aluminum and ran it up under that vent and put the sealer all over it and as you can see the stain , it's still leaking .
In the pictures you can see the roof and where the vent is , it's up along the point .
the first leak inside is about 2 ft from the point , and the other leak is down over the window .
in the 1 picture you see the outside with the 2 windows , the leak at the first leak up at the point is straight up from the left window ,but 2 ft from the point in the ceiling and the other leak is down low over the right window .
can you help me with this problem , we can't go under to look because they are cathedral ceilings and no crawl space , but there are no visible signs of damage on the roof ..need help ..thanks
I tried to load pictures but can't , I can email them to you if you give me an email address.
