My wife and I closed on a 2004-built home this past week. The first TV we tried to plug in was a 32" LCD, in the master BR. With no signal or other connections (just power, nothing else) to the TV, it would trip the 15-AMP GFCI breaker every time. I doubt this matters, but the TV was sitting on a plastic rolling cart, which in turn was on a carpeted floor.
I tried the TV in one of the other bedrooms and the breaker tripped there as well, at least 3 times before I stopped. All three bedrooms are on 15-AMP GFCI breakers, so I'm betting the TV (as well as our other TVs) will trip the breakers in all three of them.
The same 32" TV works fine in the living room, which is not on a GFCI breaker (don't recall the amperage).
The previous owner left the house completely furnished, so I know that she just had a two-prong old-school coax only TV hooked up in the master bedroom (two of them actually, and no others that I know of). I never met her but talked to her once to get the combination to a built-in safe, and she didn't seem like much for electronics, and probably never plugged much of anything into any outlet.
Also, the master bedroom and bath are on the same 15-amp GFCI breaker. I'm guessing I might end up splitting that circuit into 2 separate ones to resolve this problem?
Can I just replace the other GFCI breakers in the bedrooms with non-GFCI ones?
I am tech-savvy, but not terribly versed in electricity. I'm not afraid to hook up a multimeter or mess around with a breaker box (safely of course), so suggestions, recommendations, tests, etc. are welcome. Thanks in adcance!!
Oh, FYI my 1-year home warranty doesn't cover improperly installed wiring - it's "working as designed", not broken. Can you believe that? Well, maybe that's appropriate, I don't really know, but it sure pissed me off.
