Craftsman/Honda 6.5 mower 7 years old, but only used for about 2 of those years. The mower typically loses power once the choke springs back to the original position or opens fully. If I wedge the choke lever so the air intake is closed, the mower will run normal, but of course, overheat.
I have cleaned the carb (3) times in the past couple weeks - fully apart/used carb cleaner. No significant dirt or buildup. This will give me limited success. The mower will then stay running, but rough. The governor will fluctuate to try and help the problem. The mower will increasingly get worse. Once it shuts down, it seems to need the carb work to again keep it going.
I have also: replaced the plug (3 times, all new), new gas, high octane gas, new air filter, replaced oil, inspected and cleaned the fuel tank & fuel intake tubing from the tank to the carb, removed dirt from the top of the coil.
Been struggling with this for the pass three weeks, grass is growing again... :huh:
Fuel supply problem?
Any ideas that a DIYer can fix. Tried to take it to a professional yesterday, but he's on vacation...
Thanks for any help.
